Error in Signal Tap Logic Analyzer
Hi Vijesh,
From the signal tap, I felt like the sampling clock frequency is same or low.
As part of debugging, make one PLL and try to take the out put see pll out put is coming corrctely or not and lock signal is been high.
The above proves that the clock signal is good
- VSA006 years ago
Hi @RahulS_Intel ,
Verified the generated PLL output (300MHz) through DSO. Its coming correctly.
Vijesh S A
- Rahul_S_Intel16 years ago
Glad to know
- VSA006 years ago
Hi @RSree (Intel) ,
What I have mentioned above is there is no lockout situation with the sampling clock & the sampling clock signal is continuous when verified using DSO.
Now also the signal tap analyser is showing the discontinuity.
Is there any issue with the signal tap logic analyser or any other settings i have to do , to tap the high frequency signals.
Vijesh
