17 years agoError: Can't find the instance. Download a design with SRAM Object File containing t
Hi, I got the following Error when Signaltap was used with stratix board. Error: Can't find the instance. Download a design with SRAM Object File containing this instance. Any hel...
17 years agoFinally I correct some logic errors then the SignalTap can work although "can't find the instance" still occurs sometimes.
Plus, though the sampling clock meets the Nyquist frequency, the data wave looks bad. I think the solution is the actual Logic Analyzer.
