17 years agoError: Can't find the instance. Download a design with SRAM Object File containing t
Hi, I got the following Error when Signaltap was used with stratix board. Error: Can't find the instance. Download a design with SRAM Object File containing this instance. Any hel...
17 years agoHi this problem I also meet when build Quartus project .you can follow this step to solve it,
click "assignment " select "setting " you can see there have Signaltap setting. you don't select , this problem can pass
