17 years agoError: Can't find the instance. Download a design with SRAM Object File containing t
Hi, I got the following Error when Signaltap was used with stratix board. Error: Can't find the instance. Download a design with SRAM Object File containing this instance. Any hel...
17 years agoDid you add the signals to the signaltap .stp file before you complied and built the project?
The .stp file used for Analysis with SignalTap needs to match that used during the build. i.e. adding signals after the build does not work
