Vinayk
2 years agoEPF6016QC240 VCCIO level query
As the FPGA(EPF6016QC240-3) powered up with 5V, am curious about the output voltage levels from the FPGA, are they going to be 5V outputs too ? Atleast from datasheet it shows they will be at 5V lev...
- 2 years ago
Since this is legacy devices, I do not have much information to share here.
However, I found the device pin out information. Please refer to the link below for the pinout of the device:
Below link of the relevant documentation of the device:
Vinayk
2 years agoThank you for sharing the replies.
With the pin out information, I understand the device has the VCCIO pins, in the design as we used 3.3V for the VCCIO pins, it's obvious to have the output voltage levels aligned to the same voltage level, which would be 3.3V.
Thank you
