speranskyanton
1 year agoEPF10K20RI208-4N
Hello! Could you please confirm if the metal plate/heatsink on the EPF10K20RI208-4N can be black/gray in color, as shown in the photo? Photos of the label and the IC are attached. Thank you! ...
FvM
1 year agosperanskyanton
1 year agoHello!
Thank you!
This document states that the material is being changed to aluminum, but it does not specify its color. Previously, I have seen ICs in these packages with the heat-dissipating part in gray, but in this case it is black. Is that possible? Have you encountered heat spreaders in black color before?
Please provide your answer as soon as possible.
Thank you!
