Chrisnu
2 years agoEMIF Toolkit Eye diagram
Hi, I am running "Generate Eye Diagram" from EMIF tool kit and see the error (attached with the message). The tool runs for a while and then hangs. Not sure what's the issue. Please let me know wh...
AdzimZM_Altera
2 years agoHi Chris,
Are you testing with DDR4 EMIF Example Design?
What is the failure rate? Is it always occurs at a same time?
You may try to run nios2-terminal at the background while the Eye Diagram is been generated to avoid the toolkit from hang.
Adzim
