9 years agoEdimax USB WiFi dongle?
Hello all,
I am trying to use the Edimax USB WiFi dongle with my DE0-Nano-Soc board. I have used this dongle on my Raspberry Pi boards, so I thought this would be compatible as well. I am using a USB hub to share both the Bluetooth and Wifi dongles. Upon booting, the Nano-SoC does see the dongle but does not obtain an IP address. ifconfig doesn't show wlan0 in its configuration. I have read in other Altera forums that a driver may be needed? I have used this interface "driveless" on my Raspberry Pi with no problems. Also, it appears that the /etc/network/interfaces file is configured correctly. Has anyone successfully use a USB WiFi adapter with their Nano-soc board? Thanks in advance for the help... Here is an excerpt of the boot process: usb 1-1: new high-speed USB device number 2 using dwc2 INIT: version 2.88 booting usb 1-1: New USB device found, idVendor=05e3, idProduct=0608 usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 usb 1-1: Product: USB2.0 Hub hub 1-1:1.0: USB hub found hub 1-1:1.0: 4 ports detected Starting Bootlog daemon: bootlogd. usb 1-1.3: new high-speed USB device number 3 using dwc2 Configuring network interfaces... usb 1-1.3: New USB device found, idVendor=7392, idProduct=7811 usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1.3: Product: 802.11n WLAN Adapter usb 1-1.3: Manufacturer: Realtek usb 1-1.3: SerialNumber: 00e04c000001 wlan0: ERROR while getting interface flags: No such device eth0: device MAC address 96:ca:7d:**:**:** udhcpc (v1.20.2) started usb 1-1.4: new full-speed USB device number 4 using dwc2 Sending discover... usb 1-1.4: New USB device found, idVendor=0a12, idProduct=0001 usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0 usb 1-1.4: Product: CSR8510 A10 Here is my /etc/network/interfaces file: # /etc/network/interfaces -- configuration file for ifup(8), ifdown(8) # The loopback interface auto lo iface lo inet loopback # Wireless interfaces iface wlan0 inet dhcp wireless_mode managed wireless_essid any wpa-driver wext wpa-conf /etc/wpa_supplicant.conf iface atml0 inet dhcp # Wired or wireless interfaces auto eth0 iface eth0 inet dhcp iface eth1 inet dhcp # Ethernet/RNDIS gadget (g_ether)# ... or on host side, usbnet and random hwaddr iface usb0 inet staticNo RepliesBe the first to reply
