16 years agoDVI on Stratix II Audio Video Dev. Kit
Hello all: I am currently getting started to drive a DVI output on the Stratix II Audio Video Development Board and I am very new to it all. I have no prior experience with DVI signals, much le...
16 years agoI've done quite a bit with that board.
Well as far as driving the DVI chip, the datasheet is your best bet: http://www.siliconimage.com/docs/sii-ds-0081.pdf Basically all you're doing is driving RGB color values to the chip along with vertical and horizontal blanking signals. It's pretty straightforward. The kit includes a test example "s2gx_sdi_dvi_1pixel_per_clk.qar" in the "Examples\ManufacturingTestDesigns" folder of the kit install directory. Jake
