17 years agoDSP Development Kit, Stratix II Ed
Normally, design file download is well working.. but, sometimes the development kit initialized after downloading.... I think it is totally doesn’t make sense...what is probably cause this
17 years agook tempeku i have solved my issue, hopefully this will solve yours too.
in Quartus goto Assignments -> Settings -> Device click Device and Pin Options click the Unused Pins tab change the reserve all unused pins field to "As input tri-stated with weak pull-up resistor" my unused pins were set to drive ground by default which caused the fpga to read the configuation prom about half the time. now it reads my sof 100% of the time.
