17 years agodriving seven segment user display
Hi. I'm trying to drive the on board seven segment display on a Cyclone III development kit board EP3C120. The seven segment display is Lumex LDQ-M2212R1, quad digit. I appreciate any advice ra...
17 years agoYour 1:4 multiplex method seems basically correct. Typically, a kHz multiplex frequency would be used, generated by a synchronous counter. To achieve equal brightness of the minus sign, the duty cyle must be reduced. Unfortunately, the segment lines are driven from a 1.8V VCCIO without decreasing the current limiting resistors (could be considered a design flaw, to my opinion). Generally, for acceptable brightness, digit drivers with higher current capability than FPGA IOs would be needed.
