Elad0708
2 years agoDPX4 and DPx8 PHY
Hello, I am trying to build a PHY for DisplayPort 5.4GHz design we have. I am trying to set Dp-PHY with 4-lanes and 8-lanes, I encountered couple of issues during the process: first how can I conf...
Elad0708
2 years agoHi Aaron,
It is a little bit confusing; the question isn't only about DP. The question is about FPGA serdes regardless of DP. It is not DisplayPort by priority like the old spec iDP.
Can we get this serdes configuration:
Non-DP,
8 lanes single reference clock for all,
rate 5.4G similar to DP,
VSPE per lane similar to DP,
Max skew between all lanes 1000 pS
The important thing for us is a single clock for all 8 lanes.
Elad Rotem
zhenruan
2 years agoHi Elad,
You can copy the 4-channel Transceiver Native PHY TX IP that generated for the DisplayPort example design (the rate is set to 5.4G) and modify the channel number from 4 to 8.
Aaron
