15 years agoDMA on a DE0
Hi all, Can someone verify for me that they have DMA to SDRAM working on a DE0 board ? I've been trying to get it to work for a couple of days, but no joy. Here's how it's set up in SOPC builde...
15 years agoYes, I saw the 'small' variant, but it doesn't do any DMA testing. I was trying to keep to the supplied code (to reduce the number of things I could have done wrong :) )
The code I'm using does do a non-DMA test, which works fine. It's only when it starts the DMA test that the board hangs. I was also using offsets from top/bottom of RAM to allow the stack/heap to have space to work in. I did try using a small section in the middle of RAM as well (0xA00000 -> 0xB00000), and had the same problem. The goal is to have DMA sending video from SDRAM to a VGA core, and I want to try and get it working with a presumably "known good" solution before adding in my VGA core... I did look at the university program stuff, because it sets up a PLL for the SDRAM and the CPU, but it's all wrapped up inside a custom component, so I don't think I can get at how they've configured it, to check if my -3ns is the correct phase offset. Perhaps I'll just try various offsets and see if it helps... Cheers Simon
