15 years agoDMA on a DE0
Hi all, Can someone verify for me that they have DMA to SDRAM working on a DE0 board ? I've been trying to get it to work for a couple of days, but no joy. Here's how it's set up in SOPC builde...
15 years agoWhile your code is running the stack and heap could be in that range you tested so I wouldn't recommend testing this way. There is a smaller version of the memtest software that would fit into the on-chip memory if you boost the size a bit. The readme text for that software template should tell you how big the code footprint needs to be (it's either 4 or 8 kB.... I forget).
