DisplayPort-TX Arria 10 GX
- 2 years ago
Hi Andrey4,
Good day.
Thank you for your reply.
The reference design that is uploaded into Intel design store is a older version of Displayport TX-only design which is using Quartus version 18.1.
For you to use this design, you may need to use the same version of Quartus software to avoid any error in software and IP migration.
Screenshot1
We suggest you to use the same Quartus software version as the project you downloaded or you may generate the Displayport TX-only design directly from IP catalog in Intel Quartus software version 21.4 onwards.
Screenshot
Just to note, our design example uses Bitec FMC daughter card, so there will be definition and functions of the daughter card in the rtl code.
If you wish to use your custom board, you may need to check if the Bitec FMC daughter card schematic already included in your board. There must be a retimer on your custom board. If your schematic is the same as Bitec FMC daughter card, there is no need to remove bitec definition in the rtl code, if different, you must modify the rtl and config.h code in order to work with your board
Hope this answer is helpful.
Thank you.
ZH_Intel
Hi Andrey4,
Good day.
Screenshot1
Screenshot
Thank you.
ZH_Intel
