15 years agoDirectives define in Nios II development compiler settings
Hi, In Nios II development tool, where to define compiler directives, such as # define DHCP_SERVER thank you, OnePlusOne
15 years agoWhich Version do you use?
NIOS 10.0 EDS: you can set it under properties->nios ii application properties. There is a field called defined symbols. Put there "-d<symbol to define>" for example "-ddhcp_server". NIOS IDE 8.1: Go to properties->c/c++ build and then choose the tab tool settings. Select Preprocessor and add your define under defined symbols. Regards, Philipp
