yes2
2 years agoDiff Clk pins used as I/O on a Cyclone 10 LP
Hello, I'm aware that DIFFCLK pins can be used as general I/O, however can a single ended clock be used on one of the pins, with general I/O used on its differential pair? I am using a Cyclone 10 L...
FvM
2 years agoHi, previous post dosn't seem to answer your specific question.
I unerstand that you want to use CLK pins with single ended clock signal. In this case, p and n pin of a pin pair are independent. You can e.g. use CLK0 (DIFFCLK_0p) as clock input and CLK1 (DIFFCLK_0n) as user input signal.
Generally, refer to current pin connection guideline https://www.intel.com/content/www/us/en/docs/programmable/683137/current.html
and test the chosen pin configuration in Quartus.
