yes2
2 years agoDiff Clk pins used as I/O on a Cyclone 10 LP
Hello, I'm aware that DIFFCLK pins can be used as general I/O, however can a single ended clock be used on one of the pins, with general I/O used on its differential pair? I am using a Cyclone 10 L...
lixy
Contributor
2 years agoHi yes2,
No.
The (p) and (n) pins of a differential pair is fix. For example, in Quartus, when you set the (p)'s pin location of a differential signal, the n-terminal will be set accordingly.
You can also see this from the device Pin Information document. Example as below.
Xiaoyan
