18 years agoDeVry eSoc Max 7000
I have an eSOC developement board from DeVry with an Altera Max 7000 series CPLD chip on it. The EPM7128SLC84-15 to be exact... I left school & never ended up taking the course for which...
18 years agoIn Quartus, I see the EPM7128S84-15 available the last two digits are the speed grade. If you built the project with the -6 speed grade this may be the problem.
In Quartus, go to Assignments-Device and make sure you you have the -15 part selected. Then re-build your project. Since the "built in" program isn't working, your board may have a power supply that's not working, or the chip is just bad. I would make sure you have the 5.0 V at the MAX part as well, just to make sure. Pete
