15 years agoDevelopment Kit
Where can i find suitable *.sof and *.ptf files so i can try and run my softaware on the bourd? Thanks3 Replies
what is your board?
it always what you use. don't you have a CD(DVD) in the package? or, URL where you can download example. - Altera_Forum
Hey,
I use Stratix ii GX development board, on the CD's i found only sof files for flash,SSRAM,....but i need a general CPU sof file, am i right? Actually i dont fully undersatand what is ptf/sof files and what is the diffrens between them,all i need right now is the minimum so i can squeeze "Hello world" from my board... Thanks:) - Altera_Forum
can't you download that sof file from your JTAG cable?
I would like to make sure if you understand these steps step1: sopc builder you need to make NiosII system. creating *.ptf ( it already exist, right?) step2: QuartusII project compile you need to make QuartusII project to fix your spec in your FPGA. and compile it into *.sof ( it already exist, right?) step3: NiosII project after step1 you can also create NiosII project based on *.sopc file which you have created on step1. step4: download *.sof you can download *.sof file in several way such as JTAG, EEPROM, FPP, etc. easiest way is JTAG. step5: download NiosII program after step4. you can download NiosII program, that may tell you "hello NiosII". so, now you know which step you have missed.
