Design Security Protection
I'm working on a custom board with Stratix IV FPGA, i could not find the specific command/s to type in the command line which will generate an encrypted .jic file and .ekp file
i'm intend to use these commands in the post implementaion flow script which i will run automatically
Avi
- Avina
I was trying to run the following command:
quartus_cpf -c design_file.sof design_file.jic -d EPCS128 -s EP4SGX530 -k key_file.key key1:key2
i got an error "size of file(s) in EPCS128 exceeds memory capacity"
i need to enable the compression option - could someone advise the correct syntax for the compression enable??
AN556 page 16 mention to use an option file which contains the string compression=on
what kind of file format is the option file? could someone attach example of file with the correct syntax?
regards
Avi
- FakhrulA_altera
Hi Avina,
I saw your duplicated post here: Encrypting configuration .sof file using Command line interface
Hence, I will close this thread instead and we will continue to support you in the other posted thread.
Fakhrul
