Design not found for Transceiver Design Flow Level 2 - The Avalon MM Master
As I look into the page, seems like it is ported from wiki previously. I believe the attachment that you are referring to are previously stored in alterawiki. Since the alterawiki is no longer accessible, thus, we are unable to access the attachment or link. Sorry for the inconvenience.
Probably you could further elaborate on the specific issue that you are encountering when creating a XCVR design so that I could further assist you?
Chee Pin
I have cyclone V sockit board SoC (5CSXFC6D6F31C8ES). I am trying to set up SCVR custom phy ip core. Whenever I try to enter FPGA Fabric Transceiver Interface width of 20 and compile my design, I get the error "Error: Standard RX/TX PCS Parameter 'hd_pcs8g_digi_rx/tx_byte_deserializer' is set to an illegal value of 'en_bds/bs_by_2'. This mode is not supported with device speed grade of '8_H6', PMA WIDTH of 'twenty_bit' on atom" I saw on this link suggestion from intel (https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd03172014_8.html) but I need to use FPGA Fabric transceiver interface width of 20. SO please guide me what can I do?
