15 years agoDEo NANO VCC noise
hi i have a de0 nano and in the gpio headers i am doing pwm at 50MHZ...it have 2 gpio headers of 40 pins .. and i notice that when they are the same ... in the VCC_SYS appear a noise almost 2 Vpp... ...
15 years agoDid you connect a load to VCC? Then it may be a problem of missing bypass capacitors. If the pwm signal is driving a large capacitance, e.g. a MOSFET, the ground wire inductance can cause respective ground bounce.
