15 years agoDE3 High speed USB communication
Our application needs high speed USB data transfer between the DE3 kit and our application. I know the programming is done through the USB blaster. But, can we use the other USB ports for data transf...
15 years agoYou'll find Nios II demonstration examples for the high-speed USB interface with the DE3 CD, also Windows drivers and PC test applications. You should check, what you can re-use for your application.
