16 years agoDE3 DDR2 demo does not work with Quartus v9.1
The example from the CD to test the DDR2 memory in \DE3_demonstrations\150\DE3_DDR2\ seems to have problems under Quartus v9.1. Here’s what I’ve done: - run the demo batch in \...
16 years agoOk, i tried the DDR2 test with the files i got from elmoos, but i still don't get it working.
I created a new Projekt with bsp and copied the test source files into it. when i run the test (press button 01) the test starts, but then te cpu is kind of reseted. In the console i get things like this:===== DE3 DDR2 Test Program =====
DDR2 Clock: 266.6 MHZ
DDR2 Size: 1024 MBytes
Press any BUTTON to start test
write...
=============== DE3 DDR2 Test Program =====
write...
===== DE3 DDR2 Test Program ===== Show Progress is defined. undfining doesent help eighter. Also there seems to be a problem with printf. somtimes it doesn't print. Any ideas?? (the i2c test works when defined, does this mean the ddr works??)
