16 years agoDE3 DDR2 demo does not work with Quartus v9.1
The example from the CD to test the DDR2 memory in \DE3_demonstrations\150\DE3_DDR2\ seems to have problems under Quartus v9.1. Here’s what I’ve done: - run the demo batch in \...
16 years agoTerasic helped provide a solution. there seem to be enough differences between v8 and v9 of quartus to warrent these changes. this also allows 1G access using NIOS using these settings:
in SOPC Builder add the DDR2 SDRAM High Performance Controller and customize it with these settings for the DE3: Speed grade: 2 PLL ref clock: 50 memory clock freq: 266.667 controller data rate: half and then click modify parameters and set these: <?xml version="1.0" encoding="UTF-8"?> <preset name="Custom (DE3 1G 667 SODIMM)"> <parameter name="mem_if_memtype" value="DDR2 SDRAM" /> <parameter name="vendor" value="JEDEC" /> <parameter name="chip_or_dimm" value="Unbuffered DIMM" /> <parameter name="mem_fmax" value="333.3" /> <parameter name="mem_if_coladdr_width" value="10" /> <parameter name="mem_if_rowaddr_width" value="14" /> <parameter name="mem_if_bankaddr_width" value="2" /> <parameter name="mem_if_clk_pair_count" value="2" /> <parameter name="mem_if_cs_per_dimm" value="2" /> <parameter name="mem_if_cs_width" value="2" /> <parameter name="mem_if_dq_per_dqs" value="8" /> <parameter name="mem_if_dwidth" value="64" /> <parameter name="mem_if_pchaddr_bit" value="10" /> <parameter name="mem_if_dm_pins_en" value="Yes" /> <parameter name="mem_if_tinit_us" value="200.0" /> <parameter name="mem_if_tmrd_ns" value="8.0" /> <parameter name="mem_if_tras_ns" value="45.0" /> <parameter name="mem_if_trcd_ns" value="15.0" /> <parameter name="mem_if_trp_ns" value="15.0" /> <parameter name="mem_if_trefi_us" value="7.8" /> <parameter name="mem_if_trfc_ns" value="105.0" /> <parameter name="mem_if_twr_ns" value="15.0" /> <parameter name="mem_if_twtr_ck" value="2" /> <parameter name="mem_tac_ps" value="500" /> <parameter name="mem_tdqsck_ps" value="450" /> <parameter name="mem_tdqsq_ps" value="240" /> <parameter name="mem_tdqss_ck" value="0.25" /> <parameter name="mem_tdha_ps" value="175" /> <parameter name="mem_tdsa_ps" value="100" /> <parameter name="mem_tdsh_ck" value="0.2" /> <parameter name="mem_tdss_ck" value="0.2" /> <parameter name="mem_tiha_ps" value="275" /> <parameter name="mem_tisa_ps" value="200" /> <parameter name="mem_tqhs_ps" value="400" /> <parameter name="mem_tfaw_ns" value="0.0" /> <parameter name="mem_trrd_ns" value="7.5" /> <parameter name="mem_trtp_ns" value="7.5" /> <parameter name="mem_bl" value="4" /> <parameter name="mem_btype" value="Sequential" /> <parameter name="mem_dll_en" value="Yes" /> <parameter name="mem_drv_str" value="Normal" /> <parameter name="mem_odt" value="50" /> <parameter name="mem_tcl" value="5.0" /> <parameter name="mem_atcl" value="Disabled" /> <parameter name="mem_tcl_30_fmax" value="200.0" /> <parameter name="mem_tcl_40_fmax" value="266.667" /> <parameter name="mem_tcl_50_fmax" value="333.3" /> <parameter name="mem_tcl_60_fmax" value="333.3" /> </preset> in the top level design, use these connections: .global_reset_n_to_the_altmemddr(system_reset_n), .local_init_done_from_the_altmemddr(), .local_refresh_ack_from_the_altmemddr(), .local_wdata_req_from_the_altmemddr(), .mem_addr_from_the_altmemddr(mem_addr), .mem_ba_from_the_altmemddr(mem_ba), .mem_cas_n_from_the_altmemddr(mem_cas_n), .mem_cke_from_the_altmemddr(mem_cke), .mem_clk_n_to_and_from_the_altmemddr(mem_clk_n), .mem_clk_to_and_from_the_altmemddr(mem_clk), .mem_cs_n_from_the_altmemddr(mem_cs_n), .mem_dm_from_the_altmemddr(mem_dm), .mem_dq_to_and_from_the_altmemddr(mem_dq), .mem_dqs_to_and_from_the_altmemddr(mem_dqs), .mem_dqsn_to_and_from_the_altmemddr(mem_dqsn), .mem_odt_from_the_altmemddr(mem_odt), .mem_ras_n_from_the_altmemddr(mem_ras_n), .mem_we_n_from_the_altmemddr(mem_we_n), .oct_ctl_rs_value_to_the_altmemddr(), .oct_ctl_rt_value_to_the_altmemddr(), .reset_phy_clk_n_from_the_altmemddr(), and to meet timing, make sure to modify these under assignments:settings - Analysis & Synthesis: more settings: Parallel Synthesis ON - Analysis & Synthesis: Timing-Driven Synthesis checked - Analysis & Synthesis: Balanced - add derive_pll_clocks to top level .sdc - make sure top level .sdc and altmemddr_...sdc are in timequest timing analyzer - Fitter Settings: more: enable Beneficial Skew Optimization ON - Fitter Settings: optimize hold timing = All Paths
