15 years agoDE3 - HSMC connector layout
Hello, i have a Problem with the HSMC connector layout. On the Top of the Board there is a male HSTC conector. I designed a dautherboard with a female one to plug it in there, but the problem i...
15 years agoI had difficulties to understand your statement about the "masked" pins. Which Samtec connector type are you using in your daughterboard? The standard -D type connector with all pins populated would always be able to connect the intended signals.
P.S.: It sems to me, that Terasic did something strange when defining the "HSTC" connector based on Altera HSMC.
