15 years agoDE3 - HSMC connector layout
Hello, i have a Problem with the HSMC connector layout. On the Top of the Board there is a male HSTC conector. I designed a dautherboard with a female one to plug it in there, but the problem i...
15 years agomy female connector is like this
sig sig sig sig NC NC sig sig sig sig NC NC ...... the male connector on the DE3 board is like this: Vcc Vcc sig sig sig sig Vcc Vcc sig sig .... so when i plug it in the pins mask a signal and Vcc is connected to a signal pin. do i always have to use the female-female-adapters to connect a dautherboard then? the board i boaught (hsmc.net) is connected this way. it has a male hsmc and is mounted on the male connectors on the DE3, just was wondering why this is done this way?
