17 years agoDE2_UDP example for download here free (feedbacks are wellcomed)
Hi all. My goal is to get about 3Mbytes/sec data transfer rate from my DE2 board to PC. Here in this example I get about 1.2 Mbytes/sec. I'll accept comments about, how to speed up this, as w...
15 years ago --- Quote Start --- Hi Alberto, I attached 2 picture here. 1. Picture 1 show the UDP tester. UDP tester only listen to iport = 1024 2. ANd my LAN setting showing it LAN port =80 instead of 1024. Do i need to make sure my LAN port = 1024 so that i can listen to the board? Thanks. Regards, cafukarfoo --- Quote End --- Forgot what you're doing, you can't test this code by that way..... I will answer in your below question.
