17 years agoDE2_UDP example for download here free (feedbacks are wellcomed)
Hi all. My goal is to get about 3Mbytes/sec data transfer rate from my DE2 board to PC. Here in this example I get about 1.2 Mbytes/sec. I'll accept comments about, how to speed up this, as w...
16 years agoHi.
You have in the NIOS code:
IPsource_1 = 0xC0; // Assign ie: 192.168.0.44 IP for the DE2
IPsource_2 = 0xA8;
IPsource_3 = 0x00;
IPsource_4 = 0x2C;
IPdestination_1 = 0xxx; // Insert your IP data here
IPdestination_2 = 0xxx;
IPdestination_3 = 0xxx;
IPdestination_4 = 0xxx;
Mac_dest1 = 0xxx; // Insert your MAC address data here
Mac_dest2 = 0xxx;
Mac_dest3 = 0xxx;
Mac_dest4 = 0xxx;
Mac_dest5 = 0xxx;
Mac_dest6 = 0xxx;
Mac_source1 = 0x01; // Assign an MAC address for DE2
Mac_source2 = 0x60;
Mac_source3 = 0x6E;
Mac_source4 = 0x11;
Mac_source5 = 0x02;
Mac_source6 = 0x0F;
Well, look for in your OS "net conections" (If it's XP) and see the details for the active one. You'll be find there your machine IP and your MAC address, write them in IPdestination and Mac_dest respectively. No more to do. The NIOS code has asigned an IP for your DE2 and a Mac too, you can change it if you want for another, So your DE2 will have for ever you run that code the same IP and MAC, change the IPdest and Macdest if you run the code in another computer.....or READ some more about net connections. Cheers. Alberto.
