17 years agoDE2 SRAM read/write problem
I want make a program that can read/write data with sram on de2 board
But I has a trouble with read data! This only can read when I remove " this line" in the code! (I test this with de2 controlpanel) when I don't remove "this line" the program only can write! library ieee; use ieee.std_logic_1164.all; entity sram is port( clock_50:in std_logic; sw: in std_logic_vector(17 downto 0); ledr: out std_logic_vector(15 downto 0); sram_dq: inout std_logic_vector(15 downto 0); sram_addr: out std_logic_vector(17 downto 0); sram_we_n,sram_oe_n,sram_ub_n,sram_lb_n,sram_ce_n: out std_logic ); end sram; architecture behavior of sram is signal clk,w,r: std_logic; signal datain,dataout: std_logic_vector(15 downto 0); begin datain<="00000000"&sw(15 downto 8) ; sram_addr<="0000000000"&sw(7 downto 0); ledr<=dataout; sram_ce_n<='0'; sram_ub_n<='0'; sram_lb_n<='0'; process (sw(17 downto 16),clock_50) is begin case sw(17 downto 16) is --read when "10" => sram_oe_n<='0'; dataout<=sram_dq; --write when "01" => sram_we_n<='0'; sram_dq<=datain;--- this line when others => sram_oe_n<='1'; sram_we_n<='1'; end case; end process; end behavior;2 Replies
You forgot to drive sram_dq to three-state when not writing to the RAM.
sram_dq<= (others=>'Z') should be added to the other cases. - Altera_Forum
Thanks alot! The problem is that I don't pay enough attention for clarify interface modes!
