17 years agoDE2 SRAM Flash & Tristate Bridges
Hi, in the example DE2 designs for NIOSII SOPC systems, the SRAM is connected directly to the Avalon Bus while the Flash is connected via a tristate bridge. What is the reason for that? In th...
17 years agoSo who is doing the tristate work? It must be either the Nios system or somewhere in the fpga. Else it can't be done.
For any bidirectional pin you must have a tristate arrangement to cutoff your output drive when reading the input. Sopc does it for you plus some extras e.g. address mode transfers.
