17 years agoDE2 SRAM Flash & Tristate Bridges
Hi, in the example DE2 designs for NIOSII SOPC systems, the SRAM is connected directly to the Avalon Bus while the Flash is connected via a tristate bridge. What is the reason for that? In th...
17 years agoHi,
what do you mean address/data bus sharing? not clear. My understanding is that if avalon IF data(as opposed to fpga pins) is bidirectional then you need tristate bridge. I don't know about DE2 but I will assume avalon data is bidirectional for flash but separate input/output for sram(then bidirectional at fpga pins through your tristate bridge).
