17 years agoDE2 Send/Receive data via Ethernet Port
Hi, I am currently working on a project which requires using DE2 to send/receive data to/from a web server. I have searched on google and found the DE2 example which uses DM9000A to send and re...
17 years agoHi.
If you've never touched a computer network, maybe is a good idea to read a lot about ethernet hard specifications, plus ethernet protocols and their diferences. Also if you've a DE2 board could be quiet easy to use the onboard DM9000. Did you read my UDP example ? is totally open. It is not directly usefull for you, but would be for understsnd better, how the ethernet works. The thread is at http://www.alteraforum.com/forum/showthread.php?t=3947 Regards. Alberto.
