18 years agoDE2 Sdram
Hi all !!, my name is Alberto. I'm a very begginer in FPGA's. Most experience in microcontrollers. I'm trying to learn some about this, with the Altera DE2 board. I'm trying to test SDRAM cod...
18 years agoHello Alberto,
yes, the VHDL code is the Altera reference design I used in my applications. I found some indications, that it may have been ported from Verilog, e. g. there is a comment about an always block. The VHDL design could be implemented rather easily as far as I remember, the only change I applied was to assign a fast output enable register to the datapath OE signal, that would be a bit late otherwise. Good luck, Frank
