17 years agoDE2 I/O problems
I am a newbie to the FPGA world. I am current doing a power and temperature monitoring project using Aleta DE2 board. I have few problems with GIO pins -How do I use GIO pins to send and receive signals -Do I need a special board to read a analog voltage signal from GIO pins Sorry about the stupid questions, but I really need some help on this Thanks4 Replies
DE2 GPIO pins are basically LVTTL (3.3V logic) digital IOs. Data direction (input,output, bidirectional) has to set up for each pin in the FPGA project. The GPIO pins also have clamp diodes to 3.3V supply. Using external series resistors, you can drive them from 5V logic. 5V supplied TTL compatible logic (e.g. HCT74 family) can also be driven from 3.3V GPIOs.
The board has no analog inputs apart from audio and video codecs. To capture general analog inputs, you should connect an ADC chip. For slow signals, an ADC with serial SPI or I2C interface seems to be the most suitable method. - Altera_Forum
Really thanks for your reply.
I have a new problem now. I don't know to which pin on DE2 board I should connect the output data from ADC.:confused::confused: Thanks a lot for your help:) - Altera_Forum
Connect the ADC to GPIO pins man.
Like FvM suggests to you. - Altera_Forum
--- Quote Start --- Connect the ADC to GPIO pins man. Like FvM suggests to you. --- Quote End --- Thanks a lot
