18 years agoDE2 Expansion Header
:confused: Hi, I'm trying to do a parallel communication between the CycloneII of the DE2 kit and an external uC. Getting signals out of the DE2 kit on the expansion header is not a problem, b...
15 years agoHi,
I am doing something quite similar as to those mentioned. Can anyone provide a sample code on how to set all the pins to constant 1. I am quite new to programming expansion header and been trying multiple ways but keep getting errors. I had been using a set of code for lighting LED by flicking on the switches (just replaced the LED with the expansion header pins) but the outputs are not how I programmed it to be. Therefore, I think it's logical for me to check if I had the pin assignments correctly. Thanks in advance.
