17 years agoDE2 CODEC help
hello i have been asigned to do an audio related project as part of my graduation project... the board i am using is DE2 & the HDL is VHDL. i have been able to do a simple audio loop ba...
17 years agoif you are using the mic input to speakers you're routing a mono signal to stereo (left and right) output channels. the mono signal will be identical on the left and right speakers.
if you use the line level input you'll have a true stereo input where the left and right channel data can be different (like most recordings). you can acquire data from just 1 channel (left or right it doesn't matter as long as your signal is present on that line), you just won't have a true stereo output. for a school project it shouldn't be too critical. as far as NIOS versus RTL it depends on your own strengths and style and what you're trying to accomplish.
