16 years agoDE2-70 LCD Control sequences do not work
Hi everybody, this is my first post! :) I am working on a demonstration system over a DE2-70 board from Terasic which uses the LCD 2x16 display provided on it. The fact is that if I use the...
16 years agoHi again,
I did not put this in the other post, but I tried the same programming philosophy on a normal DE2 board and it worked fine. Has anyone been able to make the LCD work on a DE2-70 board through the HAL method? I would appreciate some help so much, because I will probably have similar problems with other parts of the board (UART for instance) which also make use of the HAL library. Thank you very much.
