12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years ago --- Quote Start --- The TOP LEVEL is DE2.VHD (vhdl file) and not HDL? - is this correct (I don't see any HDL file in project directory) --- Quote End --- HDL just means hardware description language. In my design I used de2.vhd as the top-level HDL file. You could just as easily use a .BDF file. --- Quote Start --- When I changed the "constrains.tcl" pin assignment -> I already declared the DE2-115 pin out --- Quote End --- Editing the file is not enough. You have to 'source' the file via the Tcl console to change your project settings. --- Quote Start --- So what file hold the connection between the Altera chip and TOP level? --- Quote End --- You tell Quartus what your top-level design file is. The pin names on the top-level, along with the matching pin assignments defines the top-level pins at the FPGA level. --- Quote Start --- The .PIN file is same like going in menu to Assigments -> pins correct? --- Quote End --- No. The .pin file is generated during synthesis. Look at the report files. Cheers, Dave
