12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years agoHi, when you say --- Quote Start --- You have to have matching pin assignment constraints and top-level HDL pin names. Review the .pin file generated by Quartus until things match. You're on the right track. Now you have to make sure your top-level HDL names match and check the .pin file. --- Quote End --- Just to clarify that I have understood: When I changed the "constrains.tcl" pin assignment -> I already declared the DE2-115 pin out, so now I have to use these names in project TOP LEVEL. The TOP LEVEL is DE2.VHD (vhdl file) and not HDL? - is this correct (I don't see any HDL file in project directory) So what file hold the connection between the Altera chip and TOP level? The .PIN file is same like going in menu to Assigments -> pins correct? Thanks, Roee
