12 years agoDe2-115 windows application to control Cyclone chip
Hi, I bought Altera board (development) DE2-115 In the example CD - there is a very nice PC application with UI - when pressing buttons-> altera board light leds, show LCD when you write in PC e...
12 years agoHi Roee,
Here's an example I had for the DE2 board. This is not the same board as you have, so you'll have to create your own top-level version of the design. To start with, synthesize the design so you can see how the project is created and the scripts are used. Here's the contents of the readme.txt
Altera SLD_Virtual_JTAG Example Design
4/12/2014 D. W. Hawkins ([email protected])
This example design shows how to connect the
SLD_Virtual_JTAG component to the LEDs and push
buttons on the DE2 board.
The Tcl script scripts/vjtag_cmds.tcl can be used
from the command-line application quartus_stp to
access the GPIO.
Synthesis Instructions
1. Unzip the example source, eg., into
C:\temp\de2_sld_vjtag_to_gpio
2. Start Quartus
3. Select the Tcl console
(if its not visible, select View->Utility Windows->Tcl Console)
4. Change directory to the top-level of the source
tcl> cd {C:\temp\de2_sld_vjtag_to_gpio}
5. Source the synthesis Tcl script
tcl> source scripts/synth.tcl
The console will output the following messages ...
Synthesizing the DE2 'sld_vjtag_to_gpio' design
- Quartus Version 12.1 Build 243 01/31/2013 Service Pack 1 SJ Web Edition
- Creating the Quartus work directory
* C:/temp/de2_sld_vjtag_to_gpio/qwork
- Changing to the Quartus work directory
- Creating the Quartus project
* create a new de2 project
- Creating the design files list
- Applying constraints
- Processing the design
- Processing completed
6. You can now use the JTAG programmer to download your DE2.
If your target board is not the DE2, then you will have to create
your own top-level VHDL design and corresponding pin assignments
(see constraints.tcl for an example).
GPIO Control Instructions
1. Download the DE2 board
2. Start a NIOS II IDE Shell (Cygwin console)
eg. Under Windows XP
Start->All Programs->Altera->NIOS II EDS 12.1sp1->NIOS II 12.1sp1 Command Shell
3. View the JTAG nodes
$ jtagconfig -n
1) USB-Blaster
020B40DD EP2C35
Node 00406E00 (110:8)# 0
Design hash D1C56CB2D6FF7B6F3030
4. Start quartus_stp
$ quartus_stp -s
This starts the Tcl interface.
5. Change to the project folder
6. Source the VJTAG Tcl commands
tcl> source scripts/vjtag_cmds.tcl
7. Issue VJTAG IR Tcl commands
a) Read the JTAG device IDCODE
tcl> read_idcode
0x020B40DD
b) Read the JTAG device USERCODE
tcl> read_usercode
0xDEADBEEF
c) Print the Altera Virtual JTAG hub info
tcl> print_hub_info
Hub info: 0x08086E04
VIR m-width: 4
Manufacturer ID: 0x6E
Number of nodes: 1
IP Version: 1
d) Change the VJTAG IR value
tcl> jtag_vir 0x1234
38565
The DE2 board red and green LEDs and one of the
hex displays will illuminate SLD_IR_WIDTH LEDs,
where SLD_IR_WIDTH is the top-level generic on
the DE2.vhd design (nominally set to 18-bits).
The jtag_vir instruction returns the status of
the 18-bits of switches. The value can be converted
to hex to make it easier to determine which pins
were asserted, eg.,
tcl> set sw
tcl> puts
0x96A5
which matches the settings used during this test.
8. Issue VJTAG DR Tcl commands
tcl> jtag_vdr 0x1234
0x55
A SignalTap II trace will show the data serialized
on TDI. TDO is configured to toggle, so it will
always read 0x55 or 0xAA.
Enjoy! Cheers, Dave
