HousseinKanso
2 years agoDE10 Nano programmer failing to upload my program
I have a problem while deploying a program into my DE10-nano board. I am able to detect the board successfully inside the programmer tool in Quartus. However, when I click in start, the progress fail...
Farabi_Altera
2 years agoHello,
Please refer to DE-10 Nano user guide as per attached.
You should be able to see 2 entities.
1. SOC device
2. FPGA
Choose the FPGA and load the .sof file, then program. It should work.
If you can't see above, must be something wrong with your dip switch setting to not default.
regards,
Farabi
