DE10-nano failed to boot from sd card
Hi
Did you check the SD Card image was flashed correctly?
Are you using the resource from the link below:
Jingyang, Teh
- lake_lagunita2 years ago
Yes. I've burned the image to SD card and now it works fine. What I am curious is that, I bought a completely new board and why the SD card is not correctly burned?
Hi, I 've just got another issue:
now that I could finish #2, Booting the board, I am goning to test #3, Interacting with the board. I found the START.HTML from intel github: intel/de10-nano-drivers (github.com) and the instruction is as follows:
However, after connecting the board with my laptop and update RNDIS, my laptop showed :
although the RNDIS icon has no yellow triangle: , I could not visit 192.168.7.1 shown in step 6 in START.HTML.
I am new to this board and I don't know if this step is necessary or if I can just skip it.
