YN1
7 years agoDE10-Lite board not recognized by ControlPanel and Quartus.
The USB Blaster driver was installed correctly.
However:
1. The Control-Panel application pops the attached message.
2. Quartus is unable to detect the hardware, the Processing->Autodetect is shaded and JTag Auto detect return an error (82) .
hope anyone encountered the same problem..
- DE10-Lite board from Terasic
- Windows 10
- Quartus 18.1
- Control Panel 1.0.3.0
- CalvinJoaz_P_Intel
Contributor
Hi Yaniv Nana, Good day. This might be a tool problem with Windows 10 and/or newer Quartus version. Did you tried in Windows 7? Kindly refer old thread below with similar issue has been solved with Windows7. https://forums.intel.com/s/question/0D50P00003yyPtmSAE/trouble-running-the-de2115-system-cd-control-panel-displays-error Thank you.- YN1
Hi Calvin Joazer,
Thanks for replaying and referencing to similar problem.
As it is, i solved it by doing the following:
- uninstall Quartus 18.1 and installing instead Quartus 15.1.2
- installing new bin32\ received from Teasic representative (did try the link in the user manual with no success).
I cannot claim conclusively which of the steps solved my problem.
But the ControlPanel.exe runs well on Windows10 + Quartus15.1.2
YN
- Unicorn7141
Hey, I know it's been forever but do u happen to still have the files sent to you by terasic?
Contributor
Hi Yaniv Nana, Glad you have resolved the issue and thank you for sharing the solution as well. Thank you.
