YN1
7 years agoDE10-Lite board not recognized by ControlPanel and Quartus.
The USB Blaster driver was installed correctly. However: 1. The Control-Panel application pops the attached message. 2. Quartus is unable to detect the hardware, the Processing->Autodetect is shad...
CalvinJoaz_P_Intel
Contributor
7 years agoHi Yaniv Nana,
Good day.
This might be a tool problem with Windows 10 and/or newer Quartus version.
Did you tried in Windows 7?
Kindly refer old thread below with similar issue has been solved with Windows7.
https://forums.intel.com/s/question/0D50P00003yyPtmSAE/trouble-running-the-de2115-system-cd-control-panel-displays-error
Thank you.
YN1
7 years agoHi Calvin Joazer,
Thanks for replaying and referencing to similar problem.
As it is, i solved it by doing the following:
- uninstall Quartus 18.1 and installing instead Quartus 15.1.2
- installing new bin32\ received from Teasic representative (did try the link in the user manual with no success).
I cannot claim conclusively which of the steps solved my problem.
But the ControlPanel.exe runs well on Windows10 + Quartus15.1.2
YN
- Unicorn71413 years ago
Hey, I know it's been forever but do u happen to still have the files sent to you by terasic?
