DE10-Lite and sdram controller ip
Hi Adzim, i will take a look to this but if somenone could share a simple project including sdram and niosV for DE10-Lite it could be helpfull ....
Eric
- AvinashTh_Altera11 months ago
Hi Eric:
Terasic has released Nios V + SDRAM example design on DE10-LITE board. Here is path https://download.terasic.com/downloads/cd-rom/de10-lite/) Can you try this and confirm this resolves your issue. thanks
- ETang211 months ago
Hi and thanks but ths example design use nios2-gen2 which is deprecated. When i try to replace it with NiosV/m i have errors at the compilation :
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.Warning (12251): DE10_LITE_Qsys.intel_niosv_m_0: Properties (associatedClock) have been set on interface reset - in composed mode these are ignoredWarning (12251): DE10_LITE_Qsys.intel_niosv_m_0: Properties (associatedClock,associatedReset) have been set on interface instruction_manager - in composed mode these are ignoredWarning (12251): DE10_LITE_Qsys.intel_niosv_m_0: Properties (associatedClock,associatedReset) have been set on interface data_manager - in composed mode these are ignoredWarning (12090): Entity "altera_std_synchronizer" obtained from "db/ip/de10_lite_qsys/submodules/altera_std_synchronizer.v" instead of from Quartus Prime megafunction libraryWarning (12090): Entity "altera_std_synchronizer_bundle" obtained from "db/ip/de10_lite_qsys/submodules/altera_std_synchronizer_bundle.v" instead of from Quartus Prime megafunction libraryWarning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(318): conditional expression evaluates to a constantWarning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(328): conditional expression evaluates to a constantWarning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(338): conditional expression evaluates to a constantWarning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(682): conditional expression evaluates to a constantWarning (12125): Using design file de10_lite_sdram_nios_test.v, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in projectInfo (12023): Found entity 1: DE10_LITE_SDRAM_Nios_TestInfo (12023): Found entity 1: DE10_LITE_SDRAM_Nios_TestWarning (10034): Output port "LEDR" at de10_lite_sdram_nios_test.v(49) has no driverWarning (10034): Output port "HEX0" at de10_lite_sdram_nios_test.v(52) has no driverWarning (10034): Output port "HEX1" at de10_lite_sdram_nios_test.v(53) has no driverWarning (10034): Output port "HEX2" at de10_lite_sdram_nios_test.v(54) has no driverWarning (10034): Output port "HEX3" at de10_lite_sdram_nios_test.v(55) has no driverWarning (10034): Output port "HEX4" at de10_lite_sdram_nios_test.v(56) has no driverWarning (10034): Output port "HEX5" at de10_lite_sdram_nios_test.v(57) has no driverWarning (10034): Output port "VGA_R" at de10_lite_sdram_nios_test.v(75) has no driverWarning (10034): Output port "VGA_G" at de10_lite_sdram_nios_test.v(76) has no driverWarning (10034): Output port "VGA_B" at de10_lite_sdram_nios_test.v(77) has no driverWarning (10034): Output port "VGA_HS" at de10_lite_sdram_nios_test.v(73) has no driverWarning (10034): Output port "VGA_VS" at de10_lite_sdram_nios_test.v(74) has no driverWarning (10034): Output port "CLK_I2C_SCL" at de10_lite_sdram_nios_test.v(80) has no driverWarning (10034): Output port "GSENSOR_SCLK" at de10_lite_sdram_nios_test.v(84) has no driverWarning (10034): Output port "GSENSOR_CS_N" at de10_lite_sdram_nios_test.v(88) has no driverError (10835): SystemVerilog error at riscv.pkg.sv(149): no support for unionsError (10835): SystemVerilog error at riscv.pkg.sv(333): no support for unionsError (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1163): encoded value for element "MXL32" has width 32, which does not match the width of the enumeration's base type (2)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1164): encoded value for element "MXL64" has width 32, which does not match the width of the enumeration's base type (2)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1165): encoded value for element "MXL128" has width 32, which does not match the width of the enumeration's base type (2)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1167): encoded value for element "MXL_RESERVED" has width 32, which does not match the width of the enumeration's base type (2)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1233): encoded value for element "INSTRUCTION_MISALIGNED" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1234): encoded value for element "INSTRUCTION_ACCESS_FAULT" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1235): encoded value for element "ILLEGAL_INSTRUCTION" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1236): encoded value for element "BREAKPOINT" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1237): encoded value for element "LOAD_ADDRESS_MISALIGNED" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1238): encoded value for element "LOAD_ACCESS_FAULT" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1239): encoded value for element "STORE_AMO_ADDRESS_MISALIGNED" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1240): encoded value for element "STORE_AMO_ACCESS_FAULT" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1241): encoded value for element "USER_ECALL" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1242): encoded value for element "SUPERVISOR_ECALL" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1243): encoded value for element "MACHINE_ECALL" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1244): encoded value for element "INSTRUCTION_PAGE_FAULT" has width 32, which does not match the width of the enumeration's base type (5)Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1245): encoded value for element "LOAD_PAGE_FAULT" has width 32, which does not match the width of the enumeration's base type (5)Error (12152): Can't elaborate user hierarchy "DE10_LITE_Qsys:u0|DE10_LITE_Qsys_intel_niosv_m_0:intel_niosv_m_0|DE10_LITE_Qsys_intel_niosv_m_0_hart:hart"Error: Quartus Prime Analysis & Synthesis was unsuccessful. 20 errors, 26 warningsError: Peak virtual memory: 4778 megabytesError: Processing ended: Sat Dec 13 10:39:59 2025Error: Elapsed time: 00:01:55Error: Total CPU time (on all processors): 00:02:45Error: Peak virtual memory: 4778 megabytesError: Processing ended: Sat Dec 13 10:39:59 2025Error: Elapsed time: 00:01:55Error: Total CPU time (on all processors): 00:02:45Error (293001): Quartus Prime Full Compilation was unsuccessful. 22 errors, 26 warnings- AvinashTh_Altera11 months ago
Hi Eric,
I assume you are using 25.1 std Quartus Release and to resolve these compilation error, After you replace Nios II with Nios V/m core and generate HDL, you need to add DE10_LITE_Qsys.qip file in Quartus project files and remove .qsys file. But I see that the design implements old Avalon SDRAM controller IP and this IP is not supported in latest Quartus Standard release. And you need to use workaround mentioned earlier in this thread. thanks
