ETang2
1 year agoDE10-Lite and sdram controller ip
Hello i have de10-lite and in the past i used sdram-controller ip in platform designer to connect the onboard ram to the nios processor. Now (25.1) it seems that this sdram controller is no more supp...
SimonT
11 months agoI had the same problem as well. You have to add SDC constraints.
You can take the constraints from the Eval Kit sources ./Demonstrations/SDRAM_Nios_Test/DE10_LITE_SDRAM_Nios_Test.sdc
