ETang2
1 year agoDE10-Lite and sdram controller ip
Hello i have de10-lite and in the past i used sdram-controller ip in platform designer to connect the onboard ram to the nios processor. Now (25.1) it seems that this sdram controller is no more supp...
ETang2
11 months agoHi AdzimZM_Altera and thanks for the solution that seems to work. I used "System and SDRAM Clocks for DE-series Boards" to generate the 100MHz SDRAM clock and all seems fine. The system compile and i can program the card. My system is simple : NIOS V, JTAG_UART and SDRAM controller but when i generate bsp and try to run a test hello_world there is a problem to access memory ....
Eric
- SimonT11 months ago
I had the same problem as well. You have to add SDC constraints.
You can take the constraints from the Eval Kit sources ./Demonstrations/SDRAM_Nios_Test/DE10_LITE_SDRAM_Nios_Test.sdc
