ETang2
1 year agoDE10-Lite and sdram controller ip
Hello i have de10-lite and in the past i used sdram-controller ip in platform designer to connect the onboard ram to the nios processor. Now (25.1) it seems that this sdram controller is no more supp...
AdzimZM_Altera
11 months agoHello ETang2,
We're no longer supporting SDRAM Controller IP in current Quartus Standard version.
If you want to use the SDRAM in 25.1, you can try to manually add the verilog code to your project as a custom module.
Adzim
